1 1 2 square aluminum tubing
3 min read 25-08-2025
Finding the right aluminum tubing for your project can be tricky. This guide focuses specifically on 1 1/2 square aluminum tubing, covering its properties, applications, and considerations for purchase. Whether you're a seasoned fabricator or a DIY enthusiast, understanding the nuances of this material will help ensure your project's success.
What is 1 1/2 Square Aluminum Tubing?
1 1/2 square aluminum tubing refers to aluminum extrusions with a square cross-section measuring approximately 1.5 inches on each side. The actual dimensions might vary slightly depending on the manufacturer and the wall thickness. Aluminum is chosen for its lightweight yet strong nature, corrosion resistance, and workability. This makes it ideal for a wide range of applications.
What are the Common Applications of 1 1/2 Square Aluminum Tubing?
The versatility of 1 1/2 square aluminum tubing allows it to be used in numerous applications, including:
  • Structural Frameworks: Its strength-to-weight ratio makes it perfect for building lightweight yet sturdy structures such as:
    • Frames for trailers, carts, and other mobile equipment.
    • Supports for signs and displays.
    • Components in furniture construction.
    • Architectural features and railings.
  • Mechanical Parts: Its machinability and corrosion resistance make it suitable for various mechanical applications, such as:
    • Custom machinery parts.
    • Jigs and fixtures.
    • Guardrails and safety features.
  • DIY Projects: Its ease of fabrication makes it popular for DIY projects like:
    • Custom furniture legs and frames.
    • Building enclosures and enclosures.
    • Creating custom shelving units.
What are the Different Alloys of 1 1/2 Square Aluminum Tubing?
Aluminum alloys are categorized based on their chemical composition, influencing properties like strength, workability, and corrosion resistance. Common alloys used in 1 1/2 square aluminum tubing include:
  • 6061: Known for its excellent strength, weldability, and corrosion resistance. It's a popular choice for many applications.
  • 6063: Offers good formability and extrudability, making it suitable for complex shapes. It's often used for architectural applications.
  • 5052: Features high strength and excellent corrosion resistance, making it ideal for marine and outdoor applications.
What is the Wall Thickness of 1 1/2 Square Aluminum Tubing?
The wall thickness of 1 1/2 square aluminum tubing significantly impacts its strength and weight. Thicker walls provide greater strength but increase weight. Thinner walls offer lighter weight but reduce strength. The appropriate wall thickness depends entirely on the intended application. Common wall thicknesses range from thin gauge for lighter-duty applications to thick gauge for more demanding structural applications.
Where Can I Buy 1 1/2 Square Aluminum Tubing?
1 1/2 square aluminum tubing is readily available from various suppliers, including:
  • Metal supply stores: Local metal suppliers often carry a variety of aluminum tubing in different alloys and wall thicknesses.
  • Online retailers: Numerous online retailers specialize in selling metal products, offering a wide selection and often competitive pricing.
  • Manufacturing companies: Direct sourcing from aluminum extrusion manufacturers can provide customized options and larger quantities.
Remember to specify the desired alloy, wall thickness, and length when ordering.
How Do I Cut and Weld 1 1/2 Square Aluminum Tubing?
Cutting and welding aluminum tubing requires specialized tools and techniques. Improper techniques can damage the material or create weak joints.
  • Cutting: A chop saw with an abrasive blade is suitable for most applications. For precise cuts, a miter saw or even a hacksaw can be used.
  • Welding: Aluminum welding generally requires a TIG (Tungsten Inert Gas) welder for best results. MIG (Metal Inert Gas) welding is also possible, but requires specific filler wire and expertise.
Always consult relevant safety guidelines and utilize appropriate personal protective equipment when working with aluminum and welding equipment.
This comprehensive guide provides a foundational understanding of 1 1/2 square aluminum tubing. Remember to always consult the specifications provided by the manufacturer before undertaking any project. Choosing the right alloy and wall thickness is crucial for ensuring the structural integrity and longevity of your project.
