13700 w michigan ave marshall mi 49068
less than a minute read 25-08-2025
Unveiling the Location: 13700 W Michigan Ave, Marshall, MI 49068
The address 13700 W Michigan Ave, Marshall, MI 49068 points to a specific location in Marshall, Michigan. While I cannot provide specific details about the property itself (as that would require accessing private information), I can offer information about the area and what one might find when searching this address.
This address likely falls within the western outskirts of Marshall, situated along West Michigan Avenue, a major thoroughfare in the region. The character of the area might range from residential to commercial, depending on the specific parcel of land. To gain a precise understanding of what's located at this address, you would need to utilize resources such as:
Understanding the Area:
Marshall, Michigan, is a charming city known for its historical significance and picturesque setting. The area surrounding West Michigan Avenue might include a mix of:
  • Residential areas: Single-family homes, potentially including subdivisions or more rural properties.
  • Commercial properties: Businesses could range from small local shops to larger commercial enterprises, depending on the zoning.
  • Agricultural land: Given the location, agricultural uses may be present in the vicinity, although this is less likely directly on West Michigan Avenue itself.
How to Find More Information:
To find out exactly what's located at 13700 W Michigan Ave, Marshall, MI 49068, I recommend using these resources:
  • Online Mapping Services: Use Google Maps, Bing Maps, or other mapping services. Type the address into the search bar to see aerial imagery and potentially identify the type of property.
  • County Assessor's Website: The Calhoun County Assessor's website (you'll need to search for the official site) will likely have property records containing information about the building, land ownership, and potentially its use.
  • Zillow or Similar Real Estate Sites: These websites frequently contain information about properties, including photographs and descriptions, but availability of data may vary.
Important Note: Remember that accessing and sharing private property information is restricted. The information provided above is intended to assist in identifying the general area and types of properties that could be located at this address, not to gain access to private information about the property's owners or residents.
