1967 mustang disc brake conversion kit
3 min read 25-08-2025
The 1967 Ford Mustang, a classic muscle car icon, originally came equipped with drum brakes. While charmingly nostalgic, these brakes fall short of modern safety and performance standards. Upgrading to a disc brake conversion kit is a popular modification among Mustang enthusiasts, offering significant improvements in stopping power, feel, and overall driving experience. This guide delves into the intricacies of choosing and installing a 1967 Mustang disc brake conversion kit.
What are the Benefits of a Disc Brake Conversion?
A disc brake conversion for your '67 Mustang offers several key advantages over the original drum brakes:
  • Improved Stopping Power: Disc brakes provide significantly superior stopping power, especially in wet or emergency braking situations. The larger surface area of the disc and the clamping action of the calipers result in shorter braking distances.
  • Enhanced Pedal Feel: Disc brakes offer a much firmer and more responsive pedal feel compared to the softer, sometimes spongy feel of drum brakes. This improved feel gives the driver greater control and confidence.
  • Reduced Fade: Disc brakes are less prone to brake fade (a reduction in braking effectiveness due to overheating) under heavy braking, making them safer for spirited driving.
  • Easier Maintenance: While not entirely maintenance-free, disc brakes generally require less frequent maintenance than drum brakes.
What Types of 1967 Mustang Disc Brake Conversion Kits are Available?
Several types of conversion kits cater to different budgets and skill levels:
  • Complete Kits: These kits include all necessary components: calipers, rotors, brackets, hoses, and hardware. They are generally the easiest to install but can be more expensive.
  • Component Kits: These kits offer more flexibility, allowing you to choose individual components based on your needs and preferences. This option may require more research and potentially more fabrication work.
  • Front Only vs. Full Kits: Many enthusiasts opt for a front disc brake conversion first, as the front brakes handle the majority of the stopping power. A complete front and rear conversion provides the ultimate upgrade.
Choosing the right kit depends on your mechanical aptitude, budget, and desired level of performance.
What are the Common Challenges of a 1967 Mustang Disc Brake Conversion?
While a rewarding upgrade, a disc brake conversion isn't without its potential challenges:
  • Spindle Modification: Some kits require modification to the existing spindles. This necessitates careful attention to detail and may require specialized tools.
  • Master Cylinder Upgrade: Often, a larger master cylinder is required to accommodate the increased braking force of the disc brakes.
  • Bleeding the Brakes: Properly bleeding the brake system is crucial for optimal performance and safety. Improper bleeding can lead to a spongy pedal or reduced braking efficiency.
  • Wheel Compatibility: Ensure the chosen kit is compatible with your wheels. Some kits may require specific wheel offsets or may not fit certain wheel styles.
How Much Does a 1967 Mustang Disc Brake Conversion Kit Cost?
The cost of a disc brake conversion kit varies significantly based on the brand, type (complete vs. component), and features. Expect to pay anywhere from a few hundred dollars for a basic front-only kit to well over a thousand dollars for a high-performance, complete front and rear conversion. Remember to factor in the cost of installation if you aren't performing the work yourself.
What Tools and Equipment Do I Need?
The specific tools required will depend on the kit you choose and your chosen method of installation, but generally, you will need a basic set of mechanic's tools, including wrenches, sockets, screwdrivers, pliers, and a torque wrench. You might also need a brake bleeding kit, a wheel alignment tool, and potentially a welding machine depending on the kit's requirements.
Can I Install a 1967 Mustang Disc Brake Conversion Kit Myself?
Many enthusiasts successfully install disc brake conversion kits themselves. However, it's a moderately challenging project requiring mechanical aptitude and patience. If you're unsure of your abilities, it's best to have a professional mechanic perform the installation. Improper installation can compromise safety and void warranties.
What are Some Popular Brands of 1967 Mustang Disc Brake Conversion Kits?
Several reputable brands offer high-quality kits for the 1967 Mustang. Research and compare different brands before making a purchase, reading reviews from other users to gauge their experiences and the quality of the components. Remember that price isn't always an indicator of quality, so thorough research is key.
This comprehensive guide provides a solid foundation for anyone considering a disc brake conversion for their classic 1967 Mustang. Remember always to prioritize safety and consult a professional if you are unsure about any aspect of the installation process.
